Enables the router alert IP option in the outgoing RIP control packets.
Disabled.
None.
The following command enables the RIP router alert IP option:
# enable rip use-ip-router-alert
This command is available on all platforms with a Base license or higher as described in the Switch Engine v33.1.1 Licensing Guide document.
